-   -   3.0L Rebuild - Internal Crack...advice needed (http://forums.pelicanparts.com/911-engine-rebuilding-forum/268136-3-0l-rebuild-internal-crack-advice-needed.html)
kevinpeterson2 02-23-2006 07:08 PM
Hi All-
After running the case through several cleaning cycles, I noticed an internal crack, or more appropriately, a missing piece of the case. I believe it's the external portion (internal to the case) of an oil pressure relief tube housing the relief spring. (I'll verify this location tomorrow as I'm not fully certain).
http://forums.pelicanparts.com/uploa...1140750483.jpg
In any event, has anyone else run into such a situation? Suggestions, stories, fixes are extremely welcome!
Thanks in advance,
--Kevin
JohnJL 02-23-2006 09:12 PM
Check the archives...we've all got it! Looks like crap and I couldn't believe its normal, but there you are.
Here's another string...pretty sketchy looking tho, I agree!
http://forums.pelicanparts.com/911-engine-rebuilding-forum/228138-damage-inside-engine-case.html?highlight=case
kevinpeterson2 02-25-2006 07:01 AM
Thanks for the reply, John...I'd never imagined many others had the same issue. Guess I'll go with the norm and leave as is...
Thanks again,
--Kevin
