hair cracks in 993 heads
In cleaning and bead blasting the heads of my 993 engine I found in every head a very small crack beginning in the threads of only one spark-plug to the exhaust valve seat.
Has anybody here, especially the profi head rebuilder seen this before? Can I reuse these heads with new valve guides and ignore the cracks or will finally the seat-rings fall out? Sebastian
it`s not the speed that kills, it`s the sudden stop! |
I have a set of 993 heads if you need them.
Paul Weir |
I'd take them to an experienced machine shop that has dealt with 911 engine parts before. They will be able to advice whether this can be repaird.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Paul, thank you for the offer, I`m only afraid shipping them to Germany wouldn`t be cheap. If the experts say they are crap, IŽll come back to you!
ischmitz, IŽve been to my machine shop, he is able to repair them, but this would mean pulling the valve seats, welding, cutting new threads for the plugs, machining for over-size valve seat and pressing in new seats, probably more expensive than used heads. The machinist says, there are a lot of cylinder heads of other brands where cracks are standard and do not harm, he just doesn`t know how Porsche 993 heads behave! Sebastian
hallo
i send you a email ,i have aset of 993 heads . harald |
Hi Sebastion, Shipping by US Mail is cheaper than you might think and only takes a week, I ship Porsche racing engine parts to Europe quite often.
Thanks, Paul Weir
Paul Weir |
Irrationally exuberant
Paul and Harold,
I know you guys must have seen a lot of 911 heads. I'm curious, what is your experience with 993 head cracks or 911 head cracks in general? -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
The only cracked 911-930 heads I can remember seeing came off 935 and 962 IMSA engines where the boost was turned way up.
I have a few cracked 3.8 RSR heads an a few cracked 993 heads but I am sure they came off full race engines so its more understandable.
Paul Weir |
Harald please respond to my emails.
PJ 78 911sc Targa 70 911T |
I attach a picture of the crack, highlighted with green color, otherwise it wouldn`t be visible on the picture.
Any comments? Sebastian
it would probably be cheaper to start with a good set of used heads than repair those. remove seats, weld, remachine, install new seat X 6 wouldn't be particularly cheap. seat swapping in 911 heads is dicey. i've seen too many replaced seats come loose.
Are these the 914 heads of the future?
I wonder if we will start seeing more of this....Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
We made a test today at the machine shop, heads were heated in the oven to 300 degrees Celsius=572 degrees Fahrenheit, the exhaust rings are still firmly in the heads. I think I will leave them in and hope!
Sebastian
