66mm crank question
I am looking at a 66mm std/std crank that has 1 journal that's been welded. I'm planning to use it eventually to build a 2.5 liter short stroke motor on a 7R crankcase. Should I be concerned about the journal that's been welded?
Thanks!
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 03-02-2006, 05:57 PM
PRO Motorsports
Tyson Schmidt's Avatar
Yes, especially in a SS-2.5, where it should be a very high-revving engine.
You may develop cracks near the welded journal. The higher it's revved, the greater the harmonics acting on the crank, and the greater potential for failure.
If it's just going to be a street motor, it may be O.K., but I wouldn't risk it. Never go cheap on major internal parts that could potentially destroy the entire engine.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 03-03-2006, 09:58 AM
I would rather be driving
jpnovak's Avatar
Tyson, What is your opinion on the CW vs non-CW 66mm crank for a 2.5 motor? I have seen some that say the CW is stronger and that the non-CW spins up faster. This would be for a non-full race motor but one that would see multiple track events/year.
Old 03-03-2006, 10:02 AM
andrew15's Avatar
I have a 66mm CW crank that is 1st undersized (.25mm) on both rods and mains if you need one.
I also have a 3.0 crank 1st undersized on rods and mains if anyone needs that as well.
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 03-03-2006, 10:21 AM
Thanks for the input Tyson!
Michael
Old 03-03-2006, 10:41 AM
PRO Motorsports
It's true that the non-counterweighted crank will spin up faster. The advantage of the counterweighted crank is bearing longevity, and reliability long-term. If you run the non-counterweighted crank, you need to rebuild more often, and be very dutiful on your inspections.
2004 GT3
Old 03-03-2006, 12:09 PM
jluetjen's Avatar
Do you also have the bearings to fit it?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-03-2006, 02:39 PM
andrew15's Avatar
No, I don't have the bearings, but they are available new from our host as well as others.
AM
Old 03-03-2006, 03:38 PM
Try not, Do or Do not
Henry Schmidt's Avatar
1st over bearings for a 2.2 crank are easy to find.
If done properly a first under crank should be no problem.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-06-2006, 08:57 PM
