rotorhead's Avatar
Ticking noise
After rebuilding the top end of my 3.3 (rings + head work) there is a distinct ticking sound coming from around the center rear(away from the fan) of the engine.
The ticking sound becomes noticeable after the engine warms up and seems to be about 1 every 2 engine revolutions.
I can hear it even when driving the vehicle.
I pulled the engine and re-adjusted the valve clearances accurately using a dial guage. The noise is still there. I also did a cold leakdown with the engine removed and the numbers were good (4%-6%).
Can anyone give me an idea on the steps to track this down?
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 02-24-2006, 05:20 PM
KobaltBlau's Avatar
Do you have a stethoscope, with the long tip on it for pinpointing the noise? narrowing the area down can really help.
I had a noise like this that turned out to be a broken valve spring, though it sounded to me like a poorly adjusted valve. No telling yet whether yours is the same problem though, probably not likely.
Andy
Old 02-25-2006, 06:11 AM
Forced Induction Junkie
WERK I's Avatar
Keep in mind exhaust leaks will generate a ticking sound that you would swear is mechanical noise.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-25-2006, 08:47 AM
I agree with WERK I :
Once I also had a "ticking" noise...
After some research the exhaustmanifold - head connection was leaking... And no, it wasn't noticable by traces of carbon etc.
This was also after the rebuild...
Other "ticking noise" I once had: One of the so called "elephant feet" (valve adjustment screw) was worn out. Yes, you can set your valves properly but once the engine is warmed up the worn out elephant feet will start ticking...
Good luck!
Dick
911SC cab
Old 03-01-2006, 12:00 AM
rotorhead's Avatar
Great info guys. I am back home in Australia at the end of the week and I'll check all three suggestions and let you know.
2008 BMW 320i
2006 Mercedes ML320
1998 Porsche Boxter
Old 03-01-2006, 02:18 AM
I had this for a few years and then finally did the top end. Turned out to be very worn valve guide. Hard to believe this is the cause for you since if the valve stem to guide was loose enough to make an obvious noise it would not measure or feel during the re-install, but I guess stranger things have happened. What I had was a definate tick tick sound, I thought it might be exhaust leak...then pulled the exhaust to look and $$$$ later had a rebuilt top end and lots of other stuff...clutch/etc.
Sold: 1989 3.2 coupe, 112k miles
Old 03-20-2006, 03:04 PM
My bet is on the exhaust leak as well. One of those cost me hour to hunt down. Just didn't really believe that that could have been it till I ruled everything else out....sometimes I like to learn the hard way!
Nabil
'71 S track car, 2.7L & Webers forever!
Old 03-22-2006, 07:56 PM
