-   -   82 911SC Top End Rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/268342-82-911sc-top-end-rebuild.html)
pez 02-24-2006 09:41 PM
Well I had posted that my 82 911SC with 155k was smoking and some of the members of this board correctly pointed out that Valve guides were probably going bad. I just had a visit with my mechanic who stated that I need a top end rebuild. The question I have is how difficult is it to perform the top end rebuild since the machine shop will be doing most of the work etc. Please advise and also I am waiting on my copy of Wayne's book to see if I want to attempt this job. I appreciate any input etc also if anyone knows a good machine shop in San Jose Ca.
rlane 02-25-2006 02:30 PM
I am in the middle of a "top end" rebuild myself. 78SC with 75K miles, neccesitated by Dilavar stud issues.
It is a task that takes a lot of time but is something you can do with the healp of waynes book and the great folks on here. It does take a lot of hours ! Mostly due to amateur ineffeciency but you will defintely appreciate why professional Porsche mechanics quote large sums for a rebuild.
As you read Waynes book you will see that a top end is maybe 85% of the work of a full rebuild. I am sure others who are more experienced than I will chime in but if you have 155K on that engine you might want to do the full rebuild, it is not that much more in terms of time or money.
pez 02-25-2006 05:10 PM
Thanks for your input, you probably are right I might as well do the entire job. Thanks for your input good luck with your rebuild let me know how it turns out.
Cheers,
Dave
clarelaw 02-27-2006 12:23 PM
go for it. You'll learn tomns in the process.
mtelliott 02-28-2006 11:55 AM
There is a lot you can screw up, but with help, what a rewarding project it can be when you fire it up.
crashmy911 02-28-2006 12:17 PM
It's not hard. I did it so any one can do it!!!
clarelaw 02-28-2006 01:22 PM
I had 9 broken studs. Last motor I rebuilt was my Karman Ghia when I was 17. At the time my car went down, I either had to sell the car at a loss or fix it myself. Selling was not an option so I did it myself. You will need to buy some special tools - do iit there is no other way around it. You will need some books, you'll need a dry space to rebuild the motor. It will take you twice as long as you think it will, but it is a great experience. Plus there are probably a few Pelican's in your area that will help with the tough stuff, like checking the cam timing.
Clean out your garage, buy Wayne and Bruce Anderson's books, use this forum for information and parts and you'll be fine.
