2.7 rs
I have a 74 2.7 with weber carbs I'd like to get more hp and performance out of the motor I like the 2.7 rs or should I go to the 95 mm also what all is involved like machining parts, etc.
thanks
where could I get a long or a short block 3.2 thanks
Old 03-10-2006, 07:53 PM
Hi:
You cannot install 95mm P/C's on a 2.7 due to stud-spacing conflicts and issues with the magnesium case.
The biggest practical size for a 2.7 (2687cc) are the 92mm 2.8 (2808cc) P/C's. Larger ones such as 93's are far too thin for proper ring sealing.
I would first establish what performance goals you want and then outline the various options to achieve those objectives. You should understand how expensive a good 2.7 or 2.8 will be, compared to installing a larger engine such as a 3.0 or 3.2. (I have a carbureted 2.8 in my own car, but it was NOT cheap to do).
One simply needs a realistic budget to do this right.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-10-2006, 08:16 PM
