Chain cover stud question
I'm reassembling/rebuilding an engine that I purchased in pieces. The engine is a 74 2.7L with updated oil-fed chain tensioners.
On the left chain housing there are two holes threaded for 6mm studs, but the updated chain housing covers have holes that are sized for 8mm studs.
How do people normally handle these two studs? I'm tempted to just use a 6mm bolt of the appropriate length, but I'm curious if there is a standard part that is 6mm on one end and 8mm on the other.
Old 02-26-2006, 10:33 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
74 2.0L motor? I have seen some motors that use two bolts instead of studs, do you know what year the chain housing that you are using is from?
74 911s neverending story. two feet and a jetta for now.
Old 02-26-2006, 10:59 PM
Sorry for the typo - now corrected - its a 74 2.7L engine.
Bill
1964 356 SC Coupe
1969 911 3.0L
1973 914 2.0L four & 1974 914 3.2L six, Megasquirt, twin-plug, AX car
2002 Boxster S
Old 02-26-2006, 11:15 PM
