chain sprocket holder & clamping tool?
When I was collecting the tools and parts to do a rebuild/refreshening I bought 2 tools that I do not know how to use and are not demonstrated in Wayne's book. These are the "chain sprocket holder" and the "chain tensioner clamping tool." Can somebody tell me how these are used?
Old 03-01-2006, 01:17 PM
resident samsquamch
sand_man's Avatar
In Wayne's Engine Building book, look at page 158 figure 6-8 to see how the cam sprocket tool is used.
-jeff
Old 03-01-2006, 01:38 PM
resident samsquamch
sand_man's Avatar
The year of your engine will determine which cam sprocket tool(s) you would use. Post 1980 engines have a cam bolt. Pre-1980 engines have a large cam nut that requires a 46mm crows foot in addition to the cam holder.
-jeff
Old 03-01-2006, 01:42 PM
Attached is a picture of the 2 tools I am talking about. Thanks.
don
Old 03-02-2006, 08:17 AM
resident samsquamch
sand_man's Avatar
The one on the bottom - the chain clamp - is what I was picturing from your original post. I know how it works, but didn't know how to describe it to you...that's why I didn't comment on it. As for the other thing...I have no idea. I didn't buy that one. Disregard my other posts then...I thought your speaking about the cam sprocket holder. Unless that upper tool works like a mechanical/solid tensioner to create chain tension for setting the cam timing...?????
-jeff
Old 03-02-2006, 08:24 AM
Both of these are sold by Pelican so somebody must know.....
Old 03-02-2006, 08:43 AM
safe's Avatar
The lower is used to hold the tensioner in a compressed position so you can install it.
Compress the tensioner SLOWLY in a vice and slide the clamp over it...
I don't think you need it for the carrera tensioner, only the older.
Used neither of them... although the clamp would have made my life a little easier
Magnus
Old 03-02-2006, 08:44 AM
safe's Avatar
I used a C-clamp to keep my chains tight instead of the other tool in your picture.
Magnus
Old 03-02-2006, 08:48 AM
Don,
You can also compress the tensioner in a vise and hold the center part with a nail. After installing the tensioner, pull the nail and the rod is pushed out by the internal spring against the sprocket arm.
The other doodad is installed in place of the tensioner and then adjusted to get the chain good and tight for setting the timing.
So you are getting it back together now?
Ned NYNA 11
87 Carrera targa
98 BMW 528i
98 Volvo V70
Old 03-02-2006, 09:39 AM
safe's Avatar
Originally posted by Ned nyna 11
Don,
That only works for the carrera tensioners, not the older early 911, 930 type.
Magnus
Old 03-02-2006, 12:12 PM
This setup worked like a champ!
88 Carrera
Old 03-02-2006, 11:06 PM
I think you'll like this picture much better...?
88 Carrera
Old 03-02-2006, 11:12 PM
Jim Williams's Avatar
Here's another method I use that I haven't seen anyone else post. These are simple turnbuckle "tools" found at most any well-stocked hardware store:
Right side:
And left side:
The left side also includes the tool shown in the first posters photo.
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 03-08-2006, 06:49 PM
resident samsquamch
sand_man's Avatar
Another method using the Turn Buckles:
Cam timing and chain tension
-jeff
Old 03-09-2006, 06:50 AM
Tensioning chain for cam timing
Sand-man,
I never cease to be amazed at the different ways there can be to do the same job! I forgot to mention in my previous post that I only used the turnbuckles shown in the photos as a temporary holder to remove the mechanical tensioners I use to set the cam timing (photo below), and replace them with the actual tensioners.
I'm not sure I'd want to put the needed tension in the chain with just the turnbuckles I use to do the tensioner swap, although they may also work just fine for setting the cam timing.
Jim
Old 03-09-2006, 08:06 AM
Thanks for the picture. Now I know how these work. Anybody got a picture of the C clamp being used? Also, is it OK for me to skip the sprocket alignment step if I put back the same number of shims?
Old 03-12-2006, 10:05 AM
I've heard this question asked several times before and the best answer I've heard is another question...... "How do you know the person who did it the last time did it right?" If you don't know who did it before, there will always be some doubt as to whether it was right.
Jim
Old 03-12-2006, 11:24 AM
You are right of course but it was probably done right unless the person was a raving idiot.
Old 03-12-2006, 11:57 AM
Well, you're certainly free to pursue whatever course you like, Don, it's your engine, but it doesn't take a raving idiot to make mistakes and miscalculations with these engines. And you did ask the question. Jerry Woods was the person who gave the answer the last time I heard the question asked. Always stuck with me.
Jim
Old 03-12-2006, 12:11 PM
len911's Avatar
C clamp method on my 3.2l.... Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 03-12-2006, 01:51 PM
