-   -   911/912 transaxle (http://forums.pelicanparts.com/911-engine-rebuilding-forum/269552-911-912-transaxle.html)
Mike Moss 03-03-2006 10:49 AM
911/912 transaxle
Can someone tell me if the main shaft (the one the clutch rides on) from a 914 transaxle will fit the early 5/speed 911/912 chilled aluminum case transaxle? Mine is bad and I have an oppertunity to get a 914 transaxle cheap.
Mike
jpnovak 03-03-2006 11:03 AM
It should fit no problem. The fixed 2nd gear will be a different ratio.
I have a 901 mainshaft (GA) if you need one.
