Help on cams!
Need to know which cam grind will be apropiate for a 10:1 comp ratio,3.4 engine, running EFI and ITB's, mostly street duty, any imput will be apreciated,cheers,Antonio.
Check with camgrinder here.
I consolidated a lot of information (including Camgrinder's input) into this thread. It should help you to refine your thoughts a little bit before talking to Camgrinder.
What rpm do you want the powerband to be? example, 2500 to 6500 rpms. How heavy is the car?
Weight is around #2900, 2500 to 7000 RPM's, cheers, Antonio.
My DC24 profile is the most aggresive I would choose. Anything larger will move the powerband up from the 2500 starting point
you want. If you want most the power in the 2500 to 6500 range, and are willing to give up some power at 7000 for torque at 2500 choose the DC20 profile. |
Thank You, John, I will use the DC20, pm me your phone # so I can order it.,cheers,Antonio.
Antonio,
Be sure to pick up some performance valve springs as well from John. I just got mine from John and they are great! Best Regards, Alex |
Nah, get the race ones, cool titanium retainers!!! :) Just dropped mine off at my head rebuilders!
Cheers |
| All times are GMT -8. The time now is 11:27 AM. |
