-   -   Which ones are these? Can I bore? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/271198-ones-these-can-i-bore.html)
shbop 03-12-2006 07:28 PM
Attached is a photo of a piston and cylinder from my 66' 2.0 The markings at the base of the cylinder read:
80 ZD 3
Which cylinders do I have?
I noticed in Wayne's book, under machine shop stuff, an entry for boring.
Questions: (1) Can these cylinders be bored? If so by how much?
(2) The head is stuck on the number 4 cylinder. I tried tapping from the inside of the cylinder, down on the head with my plastic dead-blow, but no luck. I'm really nervous about breaking-off fins. Is there a better way to remove a stubborn head?
http://forums.pelicanparts.com/uploa...1142220440.jpg
Thank you in advance! Aloha, Jon
cnavarro 03-13-2006 04:58 AM
Correct me if I'm wrong, that looks like a biral both by the coloring and the way the fins are cast. I picture from the top would help the clarify that further, as you can physically see two dissimilar materials in the face of the cylinder that seats against the heads. The bore should be 80mm, which you could take out to 81mm with some fresh JEs.
shbop 03-13-2006 05:40 AM
Thank you Charles. Your description of what you couldn't see was absolutely correct.
MBEngineering 03-13-2006 06:38 AM
HI pop it in the oven and warm it up, then try taping it off with a block of wood up the cylinder. good luck
regards mike
shbop 03-13-2006 07:18 AM
Aloha MIke. Too funny. I was thinking about doing just that. In another hour my wife will be walking out the door, and my cylinder will be sliding into the oven. Thanks again!
JeremyD 03-13-2006 11:08 AM
are BBQ grill may make the wifey more happy
shbop 03-13-2006 12:04 PM
10 minutes in the oven, and it popped right off. Thanks again!!
ajwans 10-19-2008 07:03 AM
Can 80mm biral cylinders be bored to accept 84mm 2.2/2.4 pistons?
andy
kenikh 10-19-2008 08:01 AM
andy
Sadly, no
tom1394racing 10-19-2008 05:45 PM
The cylinder is an 80 mm biral. These were standard for the early 2.0 motors. The 80 mm cast iron cylinders were introduced in the T motors for '68 and later.
The piston is also standard fare for the early 65-68 motors. A nice "slipper skirt" piston.
304065 10-19-2008 07:13 PM
LOL Tom! We're lucky they didn't use three compression rings!
80s can be bored to 81.
EarlyPorsche 10-25-2008 11:27 AM
What do you guys mean by slipper skirt piston? How many rings would my JE's have?
MBEngineering 10-27-2008 06:21 AM
HI andy
if you make a jig to hold the cylinders when boring them, you should get the 84mm 2.2/2.4 pistons to fit OK, as I have a 2.0Lt running round with some JE piston at 86mm in biral cylinders on a fresh bore, now covered over 3,500 miles of spirited driving by the owner.
regards mike
