Which ones are these? Can I bore?
Attached is a photo of a piston and cylinder from my 66' 2.0 The markings at the base of the cylinder read:
80 ZD 3 Which cylinders do I have? I noticed in Wayne's book, under machine shop stuff, an entry for boring. Questions: (1) Can these cylinders be bored? If so by how much? (2) The head is stuck on the number 4 cylinder. I tried tapping from the inside of the cylinder, down on the head with my plastic dead-blow, but no luck. I'm really nervous about breaking-off fins. Is there a better way to remove a stubborn head? Thank you in advance! Aloha, Jon
Jon |
Correct me if I'm wrong, that looks like a biral both by the coloring and the way the fins are cast. I picture from the top would help the clarify that further, as you can physically see two dissimilar materials in the face of the cylinder that seats against the heads. The bore should be 80mm, which you could take out to 81mm with some fresh JEs.
Charles Navarro President, LN Engineering and Bilt Racing Service http://www.LNengineering.com Home of Nickies, IMS Retrofit, and IMS Solution |
Thank you Charles. Your description of what you couldn't see was absolutely correct.
Jon |
HI pop it in the oven and warm it up, then try taping it off with a block of wood up the cylinder. good luck
regards mike
Regards mike 1983 911 SC sport, 1982 mini city |
Aloha MIke. Too funny. I was thinking about doing just that. In another hour my wife will be walking out the door, and my cylinder will be sliding into the oven. Thanks again!
Jon |
MBruns for President
are BBQ grill may make the wifey more happy
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
10 minutes in the oven, and it popped right off. Thanks again!!
Jon |
Can 80mm biral cylinders be bored to accept 84mm 2.2/2.4 pistons?
andy |
3 restos WIP = psycho
Sadly, no
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
The cylinder is an 80 mm biral. These were standard for the early 2.0 motors. The 80 mm cast iron cylinders were introduced in the T motors for '68 and later.
The piston is also standard fare for the early 65-68 motors. A nice "slipper skirt" piston.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
LOL Tom! We're lucky they didn't use three compression rings! 80s can be bored to 81.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
What do you guys mean by slipper skirt piston? How many rings would my JE's have?
HI andy
if you make a jig to hold the cylinders when boring them, you should get the 84mm 2.2/2.4 pistons to fit OK, as I have a 2.0Lt running round with some JE piston at 86mm in biral cylinders on a fresh bore, now covered over 3,500 miles of spirited driving by the owner. regards mike
