78P930's Avatar
930 Dyno Sheet
Thought this might be of interest to anyone considering modifications. I finished a rebuild on my Euro 930, #5 rod bearing failure, and put it on a dyno(MD-1750) to put some numbers to it since opinions about power output with this or that modification vary considerably. Anyway, all I did was add a K27 and SC cams to the non-cat Euro exhaust and stock IC.
Pull 1 2
Pk HP 294 283
Pk T 296 275
I know stock, this engine was rated at 300 hp and 304 p/f, I assume(hope) this was at the flywheel.
Questions:
1) Does anyone have any true measurement of drivetrain loss? Although I guess it really doesn't matter, I know what I have at the wheels.
2) Anyone w/ similar engine for comparison?
3) I later added a B&B IC but I question the efficiency since I had to remove the stock shroud that was diverting a/f through the stock IC. Any thoughts?
4) What are other modifications that would give the most bang for the buck?
Pat
10 Ford Raptor
86 930
Old 03-14-2006, 12:33 PM
78P930's Avatar
D*#@, I hate when that happens. Okay, how do I correct this?
Pat
10 Ford Raptor
86 930
Old 03-14-2006, 12:35 PM
i think you should resize the pics....
Old 03-14-2006, 01:11 PM
78P930's Avatar
Someone is going to have to walk me through this, I resized the pics and it still won't work.
10 Ford Raptor
86 930
Old 03-14-2006, 07:07 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
It needs to be under a certain pixel size, i just can't remember it off the top of my head.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 03-14-2006, 07:36 PM
