I would rather be driving
jpnovak's Avatar
cam timing made easy? adjustable sprockets
I just stumbled across these.
http://cgi.ebay.com/911-930-RSR_W0QQitemZ4618854032QQcategoryZ10408QQcmdZViewI tem
Very slick. I wonder if they will hold timing. Certainly easy to adjust. I assume that you set torque on the cam fixing nut/bolt and then clock the sprocket with the 6 adjusting bolts to set timing.
Old 03-23-2006, 01:54 PM
abit off center
cgarr's Avatar
what would really be nice is if you could adjust it on the fly!
______________________
Craig
G2Performance
Old 03-23-2006, 03:37 PM
3 restos WIP = psycho
kenikh's Avatar
a link that works...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-23-2006, 04:02 PM
Not a chance thats going into any Porsche I'm responsible for.
Timing is simple with existing cam sprockets.
My problem is all the extra parts spinning around and possibly coming loose.
I would not want a retaining screw and washer going through the cam drive, with all the havoc it would create.
This is not a improvement at all.
Maybe great for the Brit's, they love to tinker with their cars all the time.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 03-23-2006, 06:00 PM
3.4 Bigger is better
88-diamondblue's Avatar
These are made in the USA. Found them at JB Racing for $375.00 for the pair, same pictures and part numbers. What are the advantages of having the adjustable sprocket? I agree that there are more parts there but they also claim to be lighter than stock. Anybody used these?
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 03-23-2006, 09:02 PM
Less brakes, more gas!
euro911sc's Avatar
Doug-
This kind of adjustable cam wheel has been around for years... I've not heard of many of them coming apart. Though, on most other makes they are external to the engine oiling system and might not cause severe havoc. Even so, isn't the clearance from sprocket surface to cam housing cover tight enough that the screw may not be allowed out?
Just an academic discussion, really, as I agree with you. We already have adjustable sprockets... in essance
Price is way out there too!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 03-23-2006, 09:14 PM
Michael,
I don't know the answer whether the cam housing cover is close eough to catch a loose screw. Could be.....
I agree with you, the price is way out there.
I see this as another solution without a problem.
I would rather see a system that would automatically advance cam timing within a prescribed parameter.
I would also like a timing chain system for my '76 that uses a 964 and later type takeup for the idle side of the chains, rather than the sprocket wheel pushed against the chain with the tensioners.
Do these and you have my undivided attention.
Don't get me wrong, I like innovation. I just don't see it in this case.
DOUG
Old 03-24-2006, 12:12 PM
