mackpipes
Guest
Posts: n/a
stock fuel presure?
I have an '85 euro 911. What is the stock fuel presure supposed to be. It read 40 psi on the guage. Is this correct?
Old 03-25-2006, 02:35 PM
Still Doin Time
asphaltgambler's Avatar
I don't have a manual at hand but I believe the motronic pressure to be @3bar so you should be OK. Are you having a particular issue with the fuel system?
Old 03-26-2006, 08:02 AM
mackpipes
Guest
Posts: n/a
I'm experiencing knocking @ 4k rpm under full throttle. I'm guessing this means lean running issues. I'm going to check the plugs next. If they look good, what should I check next?
Old 03-26-2006, 08:27 AM
Still Doin Time
Knocking (if it is combustion related) may mean many different things. You may have too much spark advance (aftermarket chip?) or a vacuum leak from hoses, gaskets, connections.
You may have just filled your tank with a batch of poor quality fuel, the air-flow meter potentiometer may be losing contact at that very position causing a momentary lean condition.
Old 03-26-2006, 08:34 AM
rsscotty's Avatar
I have only heard a 3.2 knock a couple times.
First thing I would check is fuel quality...if you are not using premium, then try it. If you have a aftermarket chip installed, remove it and install the stock chip. I have sent chips back to Autothority with a pinging issue and have got back a chip with a different timing curve.
Check your spark plug heat range and please post what the engine has in it.
Old 03-26-2006, 10:06 AM
mackpipes
Guest
Posts: n/a
I have always run 93 octane in the motor. I did change brands when this started happening to see if it was bad fuel,...no change. I then ran a tank of Techron through it,....no change.
I am running a Steve Wong chip. However, I've had the chip in for 20k miles and this problem just started happening in the last 300 miles. I am going to put the stock chip back in and run it to see what happens. Before I do that, I'm going to pull the plugs and have a look see. I will also put a multi-meter in the AFM to see if there are any issues there. Thanks again for the suggestions, please keep um commin'.
Old 03-26-2006, 11:02 AM
Try not, Do or Do not
Henry Schmidt's Avatar
There is a knob for adjusting advance on the side of the ECU that will help you with too much advance / too low octane.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-26-2006, 02:25 PM
mackpipes
Guest
Posts: n/a
Henry, I completely forgot about that thing. Can you advise on the settings. clock wise versus counter clockwise, how many clicks there are and perhaps an educated guess as to where I should set mine. Thanks much.
Old 03-28-2006, 07:27 AM
abit off center
cgarr's Avatar
Here is where I found the info. http://www.911chips.com/fuelsys.html
______________________
Craig
G2Performance
Old 03-28-2006, 08:20 AM
Motronic systems are not my forte', but if I remember correctly there is only a 1/2 turn or so and it's only good for about 3 degrees.
Perhaps someone else has some more specific information.
Henry Schmidt
Ph: 760-728-3062
Old 03-28-2006, 09:43 AM
mackpipes
Guest
Posts: n/a
Craig and Henry, thank you both very much for the info. I'm going to try different setting and test it out. I'll post my findings.
Old 03-28-2006, 01:24 PM
