anyone have a source for a 41mm crowsfoot
Hi,
I am looking for a 41mm crowsfoot wrench to tighten the nut on the camshafts of my motor. Yes, I know the standard is 46, but I have a set of racing cams from the 70's that use the 41mm like it shows in Bruces book, Or, does any one have one that I can rent for a week. THanks Ed |
I bought a set of big feet from www.thetoolwarehouse.net , they were cheap, $70 I think for a 17pc set, 20mm - 46mm. Not the highest quality but not bad for a big set...
-Jeremy |
Here's how we remedied the problem for 906 cams.
http://forums.pelicanparts.com/uploa...1144078916.jpg http://forums.pelicanparts.com/uploa...1144078937.jpg http://forums.pelicanparts.com/uploa...1144078949.jpg |
Sounds good to me. Done that in the past.
Thanks Henry. Ed |
HI the tool you are looking for (if any one will LEND you it) is 000.721.139.00 of which is no longer aval' from porsche as i only asked on the 31 of last month, it is stamped P139, if you do not sort the spanner job out PM me and i might just let you borrow mine??
regards mike |
| All times are GMT -8. The time now is 02:19 PM. |
