-   -   Cam Timing (http://forums.pelicanparts.com/911-engine-rebuilding-forum/275361-cam-timing.html)
don hopkins 04-04-2006 03:05 PM
Cam Timing
I have just finished the cam timing process and I want to double check that I did it correctly. Is it correct that the cam dots on both the left and right cam should be both facing the same direction at the same time? And am I correct in thinking that the opening measurement at TDC (5.2mm) should alternate between crank revolutions (e.g., first revolution #1 cyc. opens, second revolution #4 opens, third revolution #1 opens again). Thanks in advance.
Don
_________________________________________
1963 356B Super
1969 911S
1981 911SC
2001 C320
2.7RACER 04-04-2006 06:51 PM
Don,
You got it. Sounds like a hot cam.
don hopkins 04-05-2006 03:15 PM
Can I get more bottom end power by advancing the cam somewhat?
camgrinder 04-05-2006 03:50 PM
Depends on the camshaft profile and a lot of other parameters. If you want, list the engine size and modifications, and I can give you my opinion.
kenikh 04-05-2006 04:00 PM
2.0S w/ Webers, right Don? Sounds like the rebuild is coming along great. Congrats!
Der fuhrer 04-06-2006 08:18 AM
Hey Don, what kind of engine are you making, and what type of cams are in it.
don hopkins 04-06-2006 03:27 PM
Gutten tag!
Its nothing fancy. I am just rebuilding the top end of my 69S. It got an S cam which is kind of peaky and I thought I could give more bottom end power while its out. I have rebuilt the tranny, resealed the interface bewteen case and chainbox, camtowers and heads, put in updated the chain tensioners and idler arms, dressed up the engine and engine compartment, put on 2 Weber 40mm IDA 3C, etc. Next winter I will do the bottom of the motor including the case, crank, etc and if I can afford it maybe upgrade to 2.2 from the current 2.0.
don
1963 356B T6 Super
1969 911S
1981 911SC
2001 C320
