Cam Timing
I have just finished the cam timing process and I want to double check that I did it correctly. Is it correct that the cam dots on both the left and right cam should be both facing the same direction at the same time? And am I correct in thinking that the opening measurement at TDC (5.2mm) should alternate between crank revolutions (e.g., first revolution #1 cyc. opens, second revolution #4 opens, third revolution #1 opens again). Thanks in advance.
Don
_________________________________________
1963 356B Super
1969 911S
1981 911SC
2001 C320
Old 04-04-2006, 03:05 PM
Don,
You got it. Sounds like a hot cam.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 04-04-2006, 06:51 PM
Can I get more bottom end power by advancing the cam somewhat?
Old 04-05-2006, 03:15 PM
camgrinder's Avatar
Depends on the camshaft profile and a lot of other parameters. If you want, list the engine size and modifications, and I can give you my opinion.
John Dougherty
Dougherty Racing Cams
Old 04-05-2006, 03:50 PM
3 restos WIP = psycho
kenikh's Avatar
2.0S w/ Webers, right Don? Sounds like the rebuild is coming along great. Congrats!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-05-2006, 04:00 PM
Der fuhrer's Avatar
Hey Don, what kind of engine are you making, and what type of cams are in it.
-58 Porsche traktor
-75 911
-85 944
Old 04-06-2006, 08:18 AM
Gutten tag!
Its nothing fancy. I am just rebuilding the top end of my 69S. It got an S cam which is kind of peaky and I thought I could give more bottom end power while its out. I have rebuilt the tranny, resealed the interface bewteen case and chainbox, camtowers and heads, put in updated the chain tensioners and idler arms, dressed up the engine and engine compartment, put on 2 Weber 40mm IDA 3C, etc. Next winter I will do the bottom of the motor including the case, crank, etc and if I can afford it maybe upgrade to 2.2 from the current 2.0.
don
1963 356B T6 Super
1969 911S
1981 911SC
2001 C320
Old 04-06-2006, 03:27 PM
