Alan.UK's Avatar
Plating the Through-bolts, yes or no?
Hi,
I have read about how you should not plate items which are put under load, unless they are specially heated after plating process. If that is the case, I take it plating the Through-bolts is a bad idea!!
Any advice
Alan.UK
Old 04-09-2006, 02:31 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We have been plating case through bolts for 20 years, hundreds of engines with no negative results.
26-28 lbs does not represent a large amount of torque on a 10 mm bolt.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-09-2006, 08:18 AM
When processing higher strength components a good plating shop will do a post plating "bakeout" to remove the embrittling hydrogen. Also, in some instances plating will reduce the fatigue strength of a part. If Henry has been doing it for some time then this last point likely doesn't apply to the through case bolts - probably because they do not operate anywhere near their fatigue life limit.
Old 04-09-2006, 09:25 AM
Alan.UK's Avatar
Henry and Jim thanks for the info. While you are here Henry, can I also ask what you do with internal nuts and parts, such as cam nuts and sprockets, do you also plate those or just get them blasted clean.
Always learning
Old 04-09-2006, 09:46 AM
