Solex cams
Hi,
I've been offered some Solex cams and I'm interested in hearing people's opinions on their suitability for my engine rebuild.
I am having a stock 2.4T engine rebuilt with
original 2.4 crank
90mm Hi comp JE 10.5:1 pistons running on UK Hi octane fuel
90mm Mahle cylinders
2.4 cylinder heads ported to 36mm inlet 32 outlet
either S cams or these Solex cams
Rejetted Zeniths with 36mm venturis
recurved stock 2.4T distributor
MSD ignition and blaster coil
I heard lots of good things about the Solex cams. What are people's opinions on how well they match up with the other components.
Thanks in advance for any comments and advice.
Rob.
Old 03-08-2018, 01:59 PM
I built a 2.8 with 9.5 cr and Solex cams, 2.7S heads, PMO carbs, excellent performance.
Solex is smooth, not peaky like S cams.
Bruce
Old 03-08-2018, 02:39 PM
I’ve used both on my race car. I would recommend the Solex cams on either a Street car or race car. S cams are just too anemic below about 5,000RPM.
-Andy
Old 03-12-2018, 01:36 PM
