shbop's Avatar
Fly-wheel orientation
Examining the fly-wheel of my 2.0, I notice a Z1 mark. The shop manual does not make reference to it. I'm imagining that it orients itself the same as the Z1 mark on the pulley. Can someone tell me if this is correct, and if not, what the correct orientation is? Thank you!
Jon
Old 04-16-2006, 03:30 AM
Try not, Do or Do not
Henry Schmidt's Avatar
If there is a Z1 mark on the flywheel that means it is a 914-6 flywheel.
Porsche flywheels bolts are off set so it will only go on 1 way. You can't make a mistake.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-16-2006, 07:40 AM
shbop's Avatar
Appreciate the reply Henry, but what about the orientation?
Jon
Old 04-16-2006, 09:18 AM
I'm missing something. The flywheel will only go on one way. The bolt patern is not symetrical.
Put the flywheel on the crank and turn it until the bolt holes line up.
Henry Schmidt
Ph: 760-728-3062
Old 04-16-2006, 09:28 AM
shbop's Avatar
OK, got it! Jesus, a little slow on this end. I got lucky when I set-up the crank to do the rods. Bolted right up first try. Thanks Henry! FNG's I'm sure, can be difficult.
Jon
Old 04-16-2006, 10:30 AM
