930 Headers
What kind of horsepower gain could I expect from a good set of headers replacing a Euro style exhaust(no cat)? Also, manufacturers are considered to produce a superior product?
Pat
10 Ford Raptor 86 930 |
You really won't gain much, if anything if you already have a Euro exhaust as that is what the aftermarket headers are designed after (the right bank crosses over to the turbo up-pipe at the bumper side, instead of at the transmission end of the crankcase as the US models were designed).
David 1986 911 Turbo |
River Rat
Pat,
I'm not sure of the exact hp gains from my B&B headers, but my car dyno'd at 421 flywheel hp (360 rwhp). Headers made a huge difference in turbo lag and the car sounds great. As a far as bang for the buck, headers are high on my list.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs. |
David, If the euro exhaust crosses at the rear, I guess I don't have it. Mine crosses at the transmission.
Dave, Those are impressive numbers, were you using the stock cam? Did you actually run on the dyno before and after installation( would help put to rest the wild speculation over drivetrain loss)? I just put in a K27-7200 and SC cams and pulled 290 RWHP at 0.9. By the way, what is EBC?
Pat,
If your car does have the US version of the headers (cross-over of the right bank occurs on the transmission end of the engine), than you stand to loose about 40lbs and decrease your spool time by about 700rpms. Dave's gains could only have occurred with a number of mods on top of the headers - cams, free-flow muffler, and higher output turbo. Once you start increasing the HP of your turbo, you better do two things: get a more efficient intercooler (no HP gains, just keeps the charge temps at a reasonable level) and (2) at a minimum, have your AFR settings check to make sure that you aren't running lean with the improved flow that you created with the previously mentioned mods - ultimately (if you decide to stay CIS) you should consider having your fuel head modified by Stephen Kaspar of IA, so that it can provide enough fuel flow at the top end. Don't forget that the stock rod bolts are only rated to the mid 400 HP range, so if you decide to do a significant number of mods you may need to consider having to replace these in your HP equation. I have first-hand experience with this as I am currently in the process of rebuilding my motor and performing some major upgrades to it. Good luck! David 1986 911 Turbo |
The main thing is to find a good dyno/operator so that you can make comparisons mod to mod. BTW, EBC is Electronic Boost Control, a fun toy and in some cases an important tool but best just to stay with your .9 spring at this point in the learning curve
Headers, it is, then. One more question concerning the fuel head mod. If the A/F is checked and doesn't lean out, is there any reason to make the modification or is there any other way to accomplish the same thing?
Thanks to all for your input. Pat
With your current set-up, 7200/sc cams, the fuel head mod is unnecessary. You really shouldn't need it unless you go with a bigger turbo such as the k27-high flow, or a k29. I run a k27-7006 with plenty of fuel to spare, but had a k29 hybrid that was on the edge with the stock fuel head. There are the rice/andial fuel enrichment units, but I think if you need more fuel the head mod is better and priced comparably. If you don't have a bigger than stock Intercooler, that should be a next step.
Thanks Mike. I have put on a B&B IC. I question its effectiveness as it sits, until I can fab up a shroud to focus airflow through, instead of around the cooler.
