Dadofour's Avatar
3.2 Motronic Cam Timing Question
I have finally gotten to the point to begin timing my 3.2 Motronic.
I am using 964 grinds from John Doughtery.
I have my metric dial indicator setup, and am able to stop at exactly 1.26mm. My issue is when I pull the pin and rotate the crank back to TDC, the cam shaft moves.
How do I imobilize the cam shaft? The motronic cams are round. I'm not sure how I can stop them from rotating.
Than
Than
My Track Schedule
1984 911 Viper Green Track Car - Parted out to fund
1993 BMW 325is Spec E36 Race Car
Old 04-21-2006, 10:44 AM
MBruns for President
JeremyD's Avatar
Cam holder tool.
Old 04-21-2006, 12:11 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
I hate when that happens. Install rockers on more than #1 and #4. The additional rockers will hold the cam in place when the pin is pulled.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 04-21-2006, 12:22 PM
Dadofour's Avatar
Cam holder tool.
Care to elaborate *grin*
The cams on the Motronic 3.2 are round on the sprocket end so I am not aware of a tool.
The only solution I can think of is some sort of soft wedge (hard rubber) to be used on a lobe other than the first.
Than
My Track Schedule
Old 04-21-2006, 12:42 PM
You could back off the rocker adjuster before removing the pin. You'd have to re-set the .004 clearance after but it should work.
-Andy
Old 04-22-2006, 09:32 PM
JeremyD's Avatar
I responded to this but guess it didn;t take. I used the cam tool to hold it the sprocket steady. You can also put the bolt (without the washer) in the end of the cam to hold that steady while you forward the flywheel.
Old 04-23-2006, 06:38 AM
Dadofour's Avatar
I like the bolt in the cam idea. It's simple, which is probably why I never thought of it. Thanks very much.
Than
My Track Schedule
Old 04-23-2006, 10:33 AM
