Alan L's Avatar
frozen exhaust studs
Any ideas on how best to remove frozen exhaust studs on 911 heads. I've tried as much oxy heat as I dare, but they are still seriously stuck.
Trying not to break them off and having to drill them out.
Alan
Old 04-22-2006, 01:21 PM
Hello, Alan.
More oxy heat, paraffin wax, hit with hammer, more oxy heat, etc..
Weld a nut to the stud..
I heat until the fins just begin to melt!
I reckon to get 10 out of 12 out ..the rest i drill..
Good luck.
Kind regards
Old 04-22-2006, 02:37 PM
Alan L's Avatar
Wooo - sounds like I've not brave enough on the heat.
I use quite a bit on the block for the head studs, but was not sure how much you could get away with on the heads.
Will try again. At the moment the stud just wants to twist rather than rotate.
Alan
Old 04-22-2006, 03:53 PM
vash's Avatar
Removing intake studs: as nasty as exhaust studs?
if i ever have to do this again, i am not doing it without that snapon collett tool. suck it up, there will be some casualties.
poof! gone
Old 04-24-2006, 02:46 PM
Alan L's Avatar
Thanks Vash.
I can get a strong grip on it - the stud is trying to twist ie break off.
Prefer it came free. Will try some more heat.
Who is that girl?
regards
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 04-24-2006, 03:44 PM
The consensus from those with experience is that if the stud is gonna break, it's gonna break. Nothing you can do about it. That said, you should still heat the crap out of all of them and try as hard as you can to avoid having to drill them out. I recently had to remove the studs from my engine and I felt lucky to get away with only 4 broken studs. Drilling them out wasn't fun, but it wasn't as bad as I expected.
Old 04-24-2006, 06:25 PM
Alan L's Avatar
One busted (drilling out partly done), one free - with lots of heat.
Man they are tight.
Seems like a waste of a good duck tail - to be buried. Those pre 76's weren't galvanised.
Alan
Old 04-24-2006, 10:52 PM
we can dream.
206 637 4071
Old 04-25-2006, 08:09 AM
