Wo ist die Rennstrecke?
DonE's Avatar
Remove Locktite 574
I've checked the archeives, but found nothing.
What is the best way to remove locktite 574 from those hard to reach areas? The areas are between the cam towers and heads.
Old 05-14-2006, 08:49 AM
Irrationally exuberant
ChrisBennet's Avatar
Re: Remove Locktite 574
I don't understand how you would find those areas "hard to reach".
I find the factory recommended gasket remover Loctite 80646 (aka Pematex Gasket Remover ) works very well.
I did a search for "gasket remover" in the Engine Building forum and found quite a few posts on thise including my own -
loctite 574 removing
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-14-2006, 10:48 AM
DonE's Avatar
I used "remove locktite 574" - didn't think to use gasket remover.
I'm trying to remove the excess around the alignment pins on the heads and the excess around the valve spring area.
Old 05-14-2006, 04:07 PM
Hello don
I've tried some gasket removal products, they work fine, but the best is :....
time and patience !
Philippe
Old 05-15-2006, 12:39 AM
