-   -   chain housing studs are loose? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/279448-chain-housing-studs-loose.html)
don hopkins 04-26-2006 01:05 PM
In the process of putting the covers on the chain housing I noticed that a couple of the studs would turn when I turned the nut. How do I go about fixing this? Do I need to buy new studs are could I use some kind of glue or sealant?
Don
___________________________
1963 356B Super
1969 911S
1981 911SC
Henry Schmidt 04-27-2006 05:35 AM
High strength Loctite it the treads are not too badly damaged.
alphie 04-27-2006 10:54 AM
what loctite # would be good?
id911T 04-27-2006 10:57 AM
Red loctite, #271
don hopkins 04-27-2006 11:09 AM
When I took my engine apart I noticed that the last time it was assembled sealant was used b/t cover and housing. But Wayne's says to put the gasket on dry. Are there differing opinions on this?
Eagledriver 04-27-2006 04:35 PM
Yes there are different opinions but the factory says to put them on dry. If you have warped covers they may not seal dry. I've tried it both ways and had no leaks either way.
-Andy
