chain housing studs are loose?
In the process of putting the covers on the chain housing I noticed that a couple of the studs would turn when I turned the nut. How do I go about fixing this? Do I need to buy new studs are could I use some kind of glue or sealant?
Don
___________________________
1963 356B Super
1969 911S
1981 911SC
Old 04-26-2006, 01:05 PM
Try not, Do or Do not
Henry Schmidt's Avatar
High strength Loctite it the treads are not too badly damaged.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-27-2006, 05:35 AM
what loctite # would be good?
'79 SC
Old 04-27-2006, 10:54 AM
id911T's Avatar
Red loctite, #271
Stephen
GruppeB #906
1970 911T
Old 04-27-2006, 10:57 AM
When I took my engine apart I noticed that the last time it was assembled sealant was used b/t cover and housing. But Wayne's says to put the gasket on dry. Are there differing opinions on this?
Old 04-27-2006, 11:09 AM
Yes there are different opinions but the factory says to put them on dry. If you have warped covers they may not seal dry. I've tried it both ways and had no leaks either way.
-Andy
Old 04-27-2006, 04:35 PM
