9elf's Avatar
Flywheel Bolts
Ladies and Gentlemen,
Just a quicky from a novice.
Can I use an air driven impact wrench on these flywheel bolts?
Thank you in advance.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan.
“Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan.
Old 05-11-2006, 12:55 AM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
yes and for good measure a little spray of PB and it will be off in no time. after this and the front pulley you wont need an impact for anything, maybe a rabbit to speed up teardown if your goin there...
74 911s neverending story. two feet and a jetta for now.
Old 05-11-2006, 12:57 AM
9elf's Avatar
Thanks porschekid, I am paranoid about stripping these bolts.
What is PB?
Old 05-11-2006, 02:56 AM
Friend of Warren
PB = Parts blaster penetrating spray. Although it is rare to see rust on these bolts a little PB couldn't hurt. I also use the impact wrench on these bolts.
Kurt V
Old 05-11-2006, 05:58 AM
rsscotty's Avatar
I personally don't ever use the impact gun to loosen or install the flywheel bolts. Lock the flywheel and them loosen with a breaker bar, then use the impact for final removal. Depending on the quality and condition of your tool, sometimes the splines are damaged or don't fit well, then you have a bolt with torn up splines.
Porsche recommends replacing these bolts after one use.
Hope this helps.
Old 05-11-2006, 07:14 AM
3 restos WIP = psycho
kenikh's Avatar
Mine came off with a standard 18" breaker bar and my 230 lbs leaning into it. It was cake. If I'd had and impact gun, I'd have used it though.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-11-2006, 10:06 AM
Irrationally exuberant
ChrisBennet's Avatar
Hope this helps.
I always replace them but I've never seen where Porsche has recommended replacing them (pre 964). Do you remember where you saw that?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-11-2006, 10:42 AM
Wayne recommends it. I don't know where the idea originated from though.
-Brian
Old 05-11-2006, 12:30 PM
rsscotty's Avatar
Porsche Crest
Chris,
Started with a Porsche dealership back in '72 and it became standard operating procedure to replace the bolts on 911 and 914 flywheels.
When we were seeing the head of the bolts break off and fall into the pressure plate clutch area you took precautions for future jobs so you didn't have to do them twice.
There was a time a few years back where we were getting the bolts from an aftermarket supplier. They were junk..you could feel them stretching just to make stock torque specs.
We torque the factory "good" bolts to 140 ft. lbs. on our race flywheels so they don't come loose. No loctite or lube used.
Standard torque on street setups.
Old 05-11-2006, 07:41 PM
Chris,
And this fellow knows what he's talking about,.....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-11-2006, 11:41 PM
I don't think that tool is designed for impact use. So I wouldn't use one.
One time I tried to save the $60 on flywheel bolts. As I was tightening up the flywheel two of the 6 bolt heads sheared right off. Yikes. I replace them now.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 05-12-2006, 04:07 AM
