Okay to bead blast valve cover sealing surface?
It's so dirty and wont come clean with scrubbing, etc. Okay to bead blast that sealing surface?
Thanks,
-Brian
Old 05-07-2006, 05:10 PM
I'd use a wet sheet of sandpaper (about 400 grit) on a flat surface. I wouldn't bead blast that surface but if you did you should do the wet sand after to take the pits out.
-Andy
Old 05-07-2006, 07:11 PM
I hear you, although it is already a pitted surface before I do anything!
-Brian
Old 05-07-2006, 07:34 PM
Irrationally exuberant
ChrisBennet's Avatar
Clean clean clean afterwards...
I use sandpaper on a piece of granite but I wouldn't use the bead blaster on the side that comes in contact with oil. I just have visions of some glass beads getting stuck in a oily nook. Maybe I worry for nothing.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-08-2006, 04:28 AM
Chris, I thought the same as you, however when I blasted the show side, I realized that the entire oil side is contaminated with bead just from being in the blast cabinet. So I went ahead and blasted the crap off that side too. The part gets thorough washing either way, so I figured why not?
I have to get myself some 400 grit sandpaper. What else is flat enough to polish the cover surafces on? I don't have any granite (that my wife will let me use).
-Brian
Old 05-08-2006, 05:33 AM
Get a piece of (free) granite from someplace that makes granite counter tops. They just throw away the "cutout" for the sink.
That's how I got mine.
Shawn* (Shawn 84 Targa) gave me the sandpaper. The sandpaper is big (12x18") with a peel and stick backside, possibly for using on a floor sander. I don't know where he got it.
-Chris
* The same Shawn who was attacked by Pelicans a while back in Off Topic. I must say, a lot of you demonstrated that you could learn a thing or two about generosity of spirit from Shawn.
Old 05-08-2006, 06:03 AM
Good idea Chris. I'll look into that, thanks!
-Brian
Old 05-08-2006, 06:18 AM
i have /use a 15"x15'x 1 1/2" plate of steel from the scrap yard. lightly dressed the surface with a good file. I use some machine oil on the surface to hold the emery sheet on and some more oil on the sheet as I draw the parts across the paper. Lazy 8s
2003 VW Passat 4 motion
1972 911 Targa
1997 Boxster
1952 H-D K model (dirt track project)
Ghosts of a few 914s & Formula Vee
Old 05-08-2006, 04:06 PM
89turbocabmike's Avatar
Brian, I use a piece of plate glass with great results, probably easier and cheaper to find.
Old 05-08-2006, 11:20 PM
Thanks! I'll be calling around for glass/granite scraps today.
-Brian
Old 05-09-2006, 09:11 AM
Even easier - picked up a polished marble sample at Lowes when I was getting emery paper.
-Brian
Old 05-09-2006, 10:12 AM
When I was looking the first place I looked was at Home Depot. They didn't have anything smooth and big as I wanted and what they had was expensive. I have a piece of glass but it is pretty thin and flexy.
-Chris
Old 05-09-2006, 02:09 PM
I found 12" x 12" and 18" x 18" marble that seems as smooth as glass. I don't think I could so better than that without getting some sort of expensive piece of machined metal like my local shop has.
-Brian
Old 05-09-2006, 03:16 PM
Glass beed cleaning aluminum surfaces that come in contact with the oil system, like the inside of the case or inside of valve covers is a really bad idea, the glass embeds in the soft aluminum and will not come out with washing but will come out when the aluminum swells from heat and will be released in the oil when you run it.
Old 05-11-2006, 05:50 PM
