leaking through ring
looking at buying my first 911. The car is an SC with 108K. I had a leakdown done on the car. All were 5's except #6 (closeset to the passenger seat) was an 11. Mechanic confirmed it was coming from the ring. Is this a car I should steer from or is this normal. Note: the car sits in heated storage in the winter and was just taken out.
Old 05-03-2006, 08:40 AM
DW SD's Avatar
Depends what you plan to use it for. Seems acceptable, if you are not planning on getting another 100k miles out of it and that you are not going to beat the heck out of it at the track. AND if the owner recognizes that there is an issue and offers some form of credit for it.
Doug
1971 RSR - interpretation
Old 05-03-2006, 10:50 AM
more miles
How will I know it is time to fix the problem?
Old 05-03-2006, 11:33 AM
adomakin's Avatar
excessive oil consumption would be a tell tale that the prob is getting worse, plug fouling up perhaps, others will no doubt chime in here though
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 05-03-2006, 11:54 AM
I've found that a single leakdown test can be confusing. I'd run the car on the hy in 4th between 3.2-3.8k rpm for 20mi and do another test.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-03-2006, 11:18 PM
