3 restos WIP = psycho
kenikh's Avatar
66mm crank number stampings
I have crank that is stamped "D665540". Common sense dictates this is probably a 66mm crank, due to the number. I was also told the engine is a 2.2, so that checks as well. I searched and this stamping nubmer comes up in no searches. Can anyone confirm?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-30-2006, 10:59 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Kenik, post a picture of the crank, you can tell very easily by the size of the oil holes (or the rod journal dimensions, or the rod part numbers).
Best
Scott
Scott Kinder
kindersport @ gmail.com
Old 04-30-2006, 09:28 PM
kenikh's Avatar
crank pic
How about this?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-01-2006, 08:30 PM
YTNUKLR's Avatar
Counterweighted 2.0/2.2 crank...oil holes are a bit smaller than on the 2.7 (on the rod journals at least). The rods are 2.0 if they have 901 part numbers. 2.4 rods are 911.103.105 and 2.2 rods are 911.101.103 IIRC. What are your plans? I'm thinking NCW T crank, 2.0 rods, JE 85mm pistons at 10:1+, DC40s...?
Cheers
Scott
Scott Kinder
Old 05-01-2006, 09:47 PM
kenikh's Avatar
I'll be using the C/W crank and lighten the rotating mass at the flywheel. I don't want the crank tearing my 1R case apart with vibration. Everything else you mentioned sounds good, except for the pistons...can you say 89mm on Nickies in a stock 2 liter spigot bore? It can be done...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-01-2006, 09:50 PM
YTNUKLR's Avatar
S%*T! You're making a 2.5L out of your original '69S motor?
Scott Kinder
Old 05-04-2006, 02:57 PM
Try not, Do or Do not
Henry Schmidt's Avatar
No, you can't put a 89 mm cylinder in a stock 2.0 spigot.
If you put a 89mm barrel in a 91.5mm spigot the barrel is too thin and will break.
The largest piston/cylinder combination you can put in a stock 2.0-2.4 spigot (91.5mm) is an 86mm bore. These are our 86mm Nikasil cylinders. This gives you an engine size of 2300 cc. on a 66mm crank and 2450 on a 2.4-2.7 70.4mm crank.
86mm
The easiest way to tell a 2.0/2.2 (66mm) crank from a 2.4/2.7 also a 3.0 turbo (70.4mm) is to look at the flywheel end of the crank. The 66mm has 2 galley holes and the 70.4 mm crank only has one.
66MM
70.4MM
CRANK ANYONE?
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-06-2006, 12:58 PM
kenikh's Avatar
It is undeniably a 70.4mm crank, then. Very interesting.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-08-2006, 07:39 PM
