Certainly if the reeds are set up right, they should cut fuel reversion at low speed, and have very little effect at high speed. Two-stroke 500cc GP bikes were making 360 hp/L towards the end, so the reeds weren't hurting performance. 906's for the street.....hmmm...
Stephen GruppeB #906 1970 911T |
Fly in the ointment?
After chewing on the is over lunch (insert rimshot here), I think the big problem will be the obstruction. To get maximum effectiveness, you need the reeds as close to the signal as possible. For a smoker, this is easy since the intake is just a hole in the cylinder wall. Reed blocks are not small items and even with what yamaha provided we were hogging out metal to stuff larger ones in. Compared to a 4-stroke there is plenty of room for them with a two-stroke.
I'm just guessing that it could be done nicely based on the porsche head design but it would require a serious redesign on the intake side of things. Most two stroke ports are square-ish with rounded corners and roofs to squeeze the rings into position again, so matching to a square reed cage is pretty obvious. Matching back to a round valve would be more interesting. RZs are 175cc per cylinder and suck on every stroke so double that number then go with a larger 6 petal block... My street RZ spins shifts at 11.5k and runs 36 mm carbs. It would be close enough to try methinks (other than the head redesign). tadd
1967 912 with centerlocks… 10 years and still in pieces! |
