911 SC engine/trans separation problem
911 SC engine and trans out of car. 4 nuts off, trans. won't slide off engine. Do I have to remove clutch lever, circlip, and 2 springs in order for the trans to slide off studs? somethings hanging it up. thanks.
Yes.
Yes,
The clutch fork shaft has to be able to rotate about 45 degrees as you pull the tranny off. -Andy |
| All times are GMT -8. The time now is 03:44 AM. |
