-   -   Can you achive the rigth tork value with loctite (http://forums.pelicanparts.com/911-engine-rebuilding-forum/282771-can-you-achive-rigth-tork-value-loctite.html)
Roslin 05-14-2006 12:15 PM
I have removed my flywheel, and saw that the bolts was not secured with loctite.
Wayne describe in his very fine book, that you should use a very
little amount of loctite 271, but can you realy get the rigth tork value, when these bolt are not oiled.. ?? i think the question is the same with the rod bolts.
Regards, Roslin -911 3,0 188 hp
