Piston/cylinder pricing and types
Finally getting it together, buying the the Mahle 98mm, 10.5 compression piston/cylinder set. Engine will be on my new Carrera case, 74.4 mm crankshaft, twin plug, 930/03 heads, S cams...efi, coil on plug etc etc
I have the prices from our esteemed hosts (Pelican) and Andial....seem pretty consistent, within $100 of each other, but just wondering if there were any places that may have significantly better prices, including Europe (will be visiting Holland for a month in September). Default is to buy from Pelican, but for $4300, if there is an advantage in buying in Europe or anywhere else around here, then my cheap Dutch heritage requires me to at least check it out..... Dennis |
Dennis,
Have you considered the QSC nickasils/JE pistons in 98's from Henry @ Supertec? I am installing a set right now in the 9.5:1's. They are under $2500 and have been tested on the turbo engines. Henry could tell you more about them. Here is a picture of them on the engine http://forums.pelicanparts.com/uploa...1147930097.jpg http://forums.pelicanparts.com/uploa...1147930204.jpg |
We'll match Andial's price if they are lower... -Wayne |
Good to see your getting these to sell. I believe the Mahle's are better but this option allowed me to upgrade to 3.4, not use my alusil PC's and to do all the things I needed to do correctly and stay within my budget.
| All times are GMT -8. The time now is 05:54 AM. |
