-   -   2.0 and chain tensioner update (http://forums.pelicanparts.com/911-engine-rebuilding-forum/283946-2-0-chain-tensioner-update.html)
shbop 05-20-2006 09:40 PM
What's the best path for the tensioner update on an early 2.0? Change the chain boxes and covers or is it possible to drill the originals? Thank you!
YTNUKLR 05-21-2006 02:44 PM
I think it would be really neat if you drilled a hole in the original covers and hooked the oil line up rather than put on 1980s parts...JMHO :)
shbop 05-21-2006 06:10 PM
Thanks Scott. I was thinking along the same line. Just wishing someone had "been there, done that" so I can try and avoid any land mines.
YTNUKLR 05-21-2006 06:37 PM
Well, I can't profess to have done the exact same thing, but it should be plug and play. Make sure you get the holes lined up right with the tensioners!
aturboman 05-21-2006 08:00 PM
I built a 67 sandcast motor a few years back that
I updated for pressure fed tensioners. I sent the original covers and chain boxes to Ollies for machining. The only snag was we had to fabricate/modify an oil line, I believe it was on the distributor side. It is not that complicated of an operation just not bolt on. Hope this helps.
YTNUKLR 05-22-2006 01:07 AM
True, the original sand cast boxes have the protrusion for the cam-driven fuel pump and they proclude the use of the original 3.2 tensioner oil line on the left side. Perhaps a machine shop can crimp together a piece of copper tubing with rubber tubing, like the oil line from the case to the cam towers. I would be wary of trying to bend the original to fit.
Cheers
Scott
