reconditioning rockers and shafts
Anyone know a good shop that can do this without a long wait?
Donnie Currently Porsche-less.....
Ollies can usually do them on exchange/core charge.
3.4 Bigger is better
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport Last edited by 88-diamondblue; 04-21-2006 at 05:51 PM.. |
You talkin' to me?
I second the recommendation for john at www.dr-camshafts.com. Great guy. Remove your adjusting screws before sending them in. Also be prepared for some of them to break when you remove them. You can get an entire set of new ones for $50 shipped.
-Chance ------------------------------------------- '90 C2 Cab - Temporarily out of service |
Thanks for the plug guys.
My website url doesnt have the - in it.
John Dougherty Dougherty Racing Cams |
I did not see a price for the resurfacing? and where can you get adjusting screws for 50 shipped?
1983 911SC 1977 911S "parting out" |
"where can you get adjusting screws for 50 shipped?"
Ditto?
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
And Camgrinder did a beautiful job on my rockers! (I'm not going to say shafts, that is too big an opening...)
user & abuser
so by exchange u mean i send the old ones, and get a different recondition ones back? like no lay over time?
because i am interested in 2 sets if the copper rings that go between the cyclinder and the block. they need to be for the 100mm p&c's. and the second item that i require, is 6 rocker shafts, and 2 rocker arms. once again either if u can supply or point me where to go. i have the old ones.... thanks again! Nick
vini vidi vici |
Check rocker bushing wear. I made a few bushings and pressed into the rockers, then honed to fit. So far so good. I think John does this also....as I understand the original bushings aren't available any longer. I don't like the looks of the originals anyway. That's my 2 cents.
Sold: 1989 3.2 coupe, 112k miles |
John (Camgrinder) fits and hones new bushings, polishes faces and checks and polishes the rocker shafts.
Beautiful work done right.
Thanks for the compliment Chris!
