Super Moderator
cstreit's Avatar
Exclamation 3.0L rod end weights
I'm working with ARP to calculate the forces my recent excursion to 8500 RPM had on my rod bolts. One of the things we need to know is the weight of the rod beyond the big end. Anyone know this?
Got a Guestimate even?
Thanks!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 05-23-2006, 06:47 PM
If you mean beyond the center of the big end, just weigh a cap. That is the mass thats trying to separate and break the bolts, but it repreresents only one contribution to a very complex set of dynamic forces. The actual strain on a rod bolt would probably be easier to measure than to calculate although if you have a good 3D model it would be easy to run an FEA.
regards,
Phil
Old 05-23-2006, 09:20 PM
Super Moderator
cstreit's Avatar
Unfortunately i don't have a scale capable of that... ARP has all the models and a program set up with all the variables they need. this is the last piece I need to provide them...
Anyone?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 05-23-2006, 09:58 PM
len911's Avatar
Don't know if this would help... Just checked my Pauter rods build sheet. They specify the big end weight as 415 grams and an overall weight of 592 grams = 177 grams. This is for a 3.2l rod. Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 05-24-2006, 04:22 PM
That might work, since the Pauter rod is actually a little on the heavy side. If you don't have it by tomorrow, I'll be able to get it for you first thing in the morning.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 05-24-2006, 04:48 PM
Super Moderator
cstreit's Avatar
Charles, if you found the rods and are willing to weigh that end, I'd sure appreciate it!
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 05-25-2006, 07:34 AM
Super Moderator
cstreit's Avatar
Maybe a wristpin also?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 05-25-2006, 07:35 AM
I don't have a wrist pin to go with them unfortunately.
Big end weight 468g
pin end weight 192g
Charles Navarro
Old 05-25-2006, 08:30 AM
Super Moderator
cstreit's Avatar
Thanks CHarles!!!!
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 05-25-2006, 09:31 AM
len911's Avatar
I just noticed that the total weight of the Pauter rod was less than the one Charles checked. 660g vs. 592g... Just for reference, Charles who made the rod you checked? Thanks! Lou
Old 05-25-2006, 09:40 AM
Super Moderator
cstreit's Avatar
Well we way overestimated the weight of a wristpin. By dead reckonging I'd say it was 75 so we put in 100grams for that. (It was certainly no mroe than 1/2 the rod-end weight!) They total force at 8533 RPM was 6k lbs. The strength of each bolt is 9k#. Two makes 18k lbs. So we're at only 1/3rd the pure clamp strength of those rod-bolts.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 05-25-2006, 09:57 AM
The rod I weighed was a stock rod. I've noticed that a lot of the aftermarket rods very closely resemble the weight distribution of the stock rods.
Charles Navarro
Old 05-25-2006, 10:25 AM
Super Moderator
cstreit's Avatar
Hmmm.... I'm thinking this is "bob weight" and not dead weight of that rod-end... Anyone got the weight of the "cap" that I could subtract from the total?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 05-25-2006, 11:20 AM
