2.4 S upgrade
Does anyone have any experience/data on approximate power increase in 2.4S when going from 8.5:1 compression to 9.5:1? (Assume nothing else is changed.)
Common rule of thumb is 10 HP for that increase. A bigger improvement would be to go to 95mm P/C set. Your engine would become a clone of a Carrera RS engine.
-Andy
72 Carrera RS replica, Spec 911 racer |
JGalt, it's not really going to do to much for the HP, although it will help a little. It will make a noticable difference in the torque both on- and off-cam.
- John
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Hello, John.
I'm really surprised to learn that John..I know you will have the data to prove it! The differnce subjectively is very significant IMHO..but as I say I know you will have the dyno plot to show different.. Kind regards David |
I suspect that what you're noticing is the increased torque across the rev range. Driving my 2.0E with S pistons compared to a 2.2E with E pistons, they're actually pretty close. The peak HP number doesn't change much since that is really a function of peak air flow. Increasing the CR does help to prop up the combustion chamber pressure above the peak torque RPM, but the percentage benefit is pretty small when you look at the peak HP number, not to mention how many people can feel a few % improvement at 6500 RPM?
But the engine's performance at lower RPM's (off-cam) is much easier to sense, especially since most of us spend most of our time at those rev's. Here's one piece of data, note that I've plotted BMEP rather then HP. BMEP is not dependant on the engine size like HP is. BMEP RPM 70S 72S CR> 9.8:1 8.5:1 2000 133 125 2500 133 133 3000 138 143 3500 144 151 4000 153 160 4500 162 167 5000 166 172 5500 168 171 6000 167 169 6500 164 162 7000 150 148 Note that the '70S had better performance below 2500 RPM, and above 6500 RPM. The '72S did better in between? Why? I suspect that the lower dome in the pistons improved the combustion chamber shape (always a weakness of Hemi heads) which made up for the reduction in CR. Now getting 9.8:1 in a 2.4 liter 72S doesn't require as large of a dome as in 2.2 70S because the 2.4 liter 72 has a longer stroke, which allows you get the same CR with a smaller dome. So I would expect the 2.4 with 9.8:1 to have a BMEP level more like the best of both of those columns of data.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 05-24-2006 at 03:57 PM.. |
I hate to slip in like this but this begs the question of will 2.2Spistons on the 2.4L crank have a compression ratio of higher than 9.8? You said "getting 9.8 in a 2.4 '72S doesn't require as large a dome as in the 2.2S due to the lengthened stroke. I ask as I'm now concerned as I'm putting 2.2S pistons on that crank and I don't want more than 9.8!!
Thanks Nabil
'71 S track car, 2.7L & Webers forever! |
Hello Nabil.
No worry..this is the normal replacement piston for the 2.4S now..few use the low CR..Bruce Anderson notes this results in about 9.8, ie less than expected..the factory must have wrongly quoted the CR of the 2.2S.. Kind regards David |
thanks brother, Had me sweating.
nabil
Best way to know for sure would be to "cc" your heads, cylinder volume, and compute the cr. So many things can change it, from surfacing the heads and cylinders, etc. You never ,know what has happened to these parts before you aquired them. Just another HO
Jon |
Author of "101 Projects"
If I were wanting more power out of the 2.4, I would take the case, and put it in my garage, and find a 2.7 7R case and build that up into a 2.7 with S cams, and have the fuel injection pump recalibrate to 2.7RS specs. As I say in the book, it will cost you a lot of money to rebuild a 2.0 or a 3.2 - you might as well rebuild the highest horsepower engine you can create.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Hi
Moving on from Waynes suggestion, put your 2.4S in the corner of your garage and dont touch it! Build or buy a totally new 2.7/2.8 engine, someday putting the 2.4S back in the car (if the numbers match) will double its value My 2c worth Neven |
