2.2 to 2.5 engine rebuild
I am rebuilding a 2.2 using 2.7 cylinders/pistons. THis car will be a street daily driver. THis is what I have so far ... please give feedback:
1. Original 2.2 crank and rods and hopefully case. 2. Nikasil 2.7 cylinders and RS domed pistons. 3. Port / polish heads 4. Solex cams 5. Several mods as listed in Dempsey's text Questions: What are risks with case mods and how to avert problems? WHat will be eventual compression and can I increase easily without additional piston purchase? Must I purchase some JE's? Any feedback appreciated. |
GAFB
Why not spend another $350 and get the 70.4mm crank and rods, and have a 2.7?
Several BMWs |
3 restos WIP = psycho
Compression will be low; in the 7.5:1 realm using the 66mm crank. The only way to remedy this is to order JE pistons in the CR of your choice. You could probably sell the new Mahle pistons for a decent enough price to make it a wash.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
I think that the higher compression ratio will be key in preserving torque in the lower rev ranges. First time I do something like this, though, and I'm still at least a month away from driving. Michel Richard |
Stressed Member
C-
I'm doing the exact same build. I bought JEs, but if you have good RS pistons, I'd just do a 2.7 so that you end up with a decent compression ratio. Either way, I'd think about buying a 7R case. That's what I did. After realizing how much it would cost to enlarge the 2.2 spigots and install piston squirters, and realizing how cheap 7R cases were, it was an easy choice. The extra strength of the 7R case is a bonus. My 2.2 case sits on a shelf, in case there is ever a need for a "numbers matching" car. -Scott
'70 911E short stroke 2.5 MFI. Sold ![]() ![]() ![]() '56 Cliff May Prefab |
