johncmng's Avatar
Angry Separating fan shroud and generator help
I'm having problem separating the fan shroud and the generator.
I have removed all the nuts from the back of the unit.
The ones that are on the edge of the bracket.
Am I missing a nut or two?
3.2 Carrera
Old 08-21-2006, 08:11 AM
On my '78 SC 3.0 there were 6 (as I recall) nuts spaced pretty evenly around the perimeter of the shroud, all of them had to come off before the shround will come off. Of course, then you move to the next step: separating the alternator from the fan housing (hint: time for hammer and block of wood!).
1978 SC Targa (mine since 1985) - ah, youth . .
2008 E63
2004 Van's RV-6 (O-360-A1A & Hartzell C/S) - just for fun
Old 08-21-2006, 09:53 AM
David's Avatar
Pull harder and wiggle it some. I don't think the bolts usually bind up, it's just a tight fit between the alt. housing and the fan housing.
Old 08-21-2006, 11:14 AM
Just remember there is a ground from the alternator> case.... If thats not it it might be your wires are not loose enough... I had to feed the wires throught the shroud to get enough room to pull the alternator back cover and unbolt the wires.... Be sure your battery in disconected.
Good luck
Old 08-21-2006, 01:24 PM
hold the housing with both hands, fan side down, and firmly knock the edge of the housing a couple of times on a block of wood or several rags folded flat on the floor. turn it 180° and do the other side. repeat as needed. gravity and inertia will work for you.
206 637 4071
Old 08-21-2006, 03:26 PM
johncmng's Avatar
It worked!
Thanks to everyone for your help.
Old 08-22-2006, 07:32 AM
