Air pump ports
Any ideas where to get a M12x1 plug to plug the air pump port in the head? I am trying to plug the port that is just below the exhaust port where the air pump nozzle went. The Googles are not helpful, tried McMaster. No luck. I cant be the first guy to do this, but I found nothing with a search.
Old 06-08-2017, 02:44 PM
I got them from "bolt depot" and you can buy them each.
I'm pretty sure you want 10x1mm
Bruce
Old 06-08-2017, 03:47 PM
It is 12x1 for sure. This is for a 2.0 out of a 68 911L
Old 06-09-2017, 08:10 AM
disband
juanbenae's Avatar
I used a 914 brake component I found in a thread many moons ago. I would not even know where to begin to search for the thread, but maybe looking around in the 914 brake parts catalog might be fruitful?
Old 06-09-2017, 06:26 PM
disband
juanbenae's Avatar
I think these are them Part #: 914-352-000-00-SIC found them in the pelican 914 section
Old 06-09-2017, 06:33 PM
They are also listed here on Pelican as Air Injection Smog Pump Port Plug, sold individually.
Harold
87 911 Carrera
82 911SC
Old 06-09-2017, 07:15 PM
disband
juanbenae's Avatar
^^^what he said^^^
although the Patrick MS set for $30 or so & no cal sales tax seems like a sweet option...
Old 06-09-2017, 07:18 PM
So, believe it or not, neither Pelican nor Stoddard has the ability to measure the threads on that 914 part. Looking at the pic that pelican has on the site they look to be 1.5 pitch. I also called Patrick and theirs are 10x1.0, so that wont work. I guess I will spend some time in the machine shop and turn my own. Thanks for the help guys.
Old 06-12-2017, 09:00 AM
disband
juanbenae's Avatar
buy a single of the 914 part and see if it works before acquiring all of them. I am confident they are what I used to fill the ports on my old 78 when I went to SSI's.
Old 06-12-2017, 09:24 AM
Irrationally exuberant
ChrisBennet's Avatar
Try BelMetric:
https://www.belmetric.com/12mm-metric-drain-plugs-c-11_90_870/
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-12-2017, 09:25 AM
Bell Metric was the first call I made. No luck. Your SC has 10x1 my 68L has 12x1
Old 06-12-2017, 09:44 AM
My bolt place shows 12x1.25 as extra.fine thread
Bruce
Old 06-12-2017, 10:09 AM
Oh, I misunderstood. I thought you were looking for 12x1.5.
Would a Kawasaki 12x1 ("12x10") drain plug work? (Part # 92066-1222)
These are tapered right?
https://www.adaptall.com/products/Metric/port/9030M/9030M-12X1.0.php
https://www.boschhydraulic.com/products.asp?id=2462
Old 06-12-2017, 10:12 AM
I'll have to look at that. The relief that the port is in may not have the clearance for a conventional hex head
Old 06-12-2017, 03:42 PM
