Wil Wil is offline
79 SC disasembly
OK, Ive got the head off engine, did not take off lifters, the only thing preventing complete removal is chain restricted by brown plastic chain guide.
It has 2 round fasteners.
How does this chain guide come off?
is there some kind of nut or spring release?
Then, when I get the head off, I can take it down in the shop where there is better lighting to see what I am dealing with.
thanks
Old 06-09-2006, 12:32 PM
GBStu's Avatar
Wil,
I couldn't imagine how I’d have disassembled and rebuilt my engine without Wayne's book, here's the link:
http://www.101projects.com/911-Rebuild/index.htm
Good luck, Stu
Note, each chain ramp "snaps" onto two shafts, the chances of removing them without damaging the ramp is pretty low....these ramps are consumables during a rebuild
Old 06-09-2006, 01:57 PM
Brown Plastic chain guide.....
Wil,
These chain guides your were refering could be easily removed by prying them out. They are just snag tigth held by the 2 metal posts/studs with grooves.
Pry them from behind and will just pop off after sliding a few mm out. Installation is much easier. Just slide them and hear it snap and lock. Hope this will get you moving.
Tony
Old 06-11-2006, 05:51 PM
