Fidanza lightweight flywheel; 911SC
I bought a lightweight Fidanza flywheel for my 83 911SC and it came with a disclaimer stating that I had to use the flywheel pilot bushing from the early 911SC model, #901-102-025-01. This was the press fit pilot bushing vice the 3 bolt unit that attaches to the end of the crankshaft. Has anyone used this flywheel with the earlier pilot bushing and does it fit ok??
Erk ![]() PCA Member restored 79 911SC Euro green, mean and ready to rock |
i have the same flywheel and yes the early pilot bearing fits fine. the problem i ran into however is that there is a case bolt boss that sticks out a little more than the others and it hits the flywheel. i called the company and they said that because it is aluminum that they needed to make the flywheel thicker and that a little filing is sometimes needed on the boss to clear the flywheel. pretty minor but just so you know.
BMW 128i 73 rsr clone - sold 68 912 project to become 911r (almost done!) |
I am running that same setup, and had exactly the same experience with the bolt boss. No problem to clearance it just a bit.
Joe 996 GT3 RSR |
great information. Thanx for the response. Now I can sleep at nite!
Less brakes, more gas!
How's the set up work for street/track?
-michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Mine is a race-only car, but I have heard of many people running it on street cars with no problems.
Joe 996 GT3 RSR |
Try not, Do or Do not
We have used Fidanza flywheels in the past and discovered that they are not very rigid. They can flex so much that the flywheel can hit the engine case behind the flywheel. In extreme circumstances we have seen the flywheel rivets machined off causing catastrophic failure.
Use at your own risk. BTW: Fidanza was happy to replace the defectives flywheels but offered no design improvements and no explanation for the failures.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I've had issues not only with fitment, but the same kinds of failures. If one does some research, there are better alternatives, IMHO.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
what are the alternatives?
Bruce 83 SC 94 993 |
Sachs Power clutch is made with an aluminum housing to reduce weight.
We are working on an RSR style steel flywheel. Bremtec built them in the past but I have not seen an available for many years.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 06-12-2006 at 10:32 AM.. |
We used to use the Tilton aluminum ones but those are NLA. There is a fellow back East thats makes an excellent one from 7075 T6 and a replaceable steel lining.
Banned
