Me like track days
Craig 930 RS's Avatar
Question CIS fuel head pic and 2 questions - parts availibility?
The one pic serves the two CIS fuel head questions:
1) Are the aluminum looking washers in the bag a good replacement for the copper coated (appears as so) washers?
2) Can one still get these teeny fuel filter looking devices which pop inot the top of the fuel head - direclty under the fuel lines? This one is pretty thrashed.
The fuel head is off to IA in exchange for a modified IA fuel head -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-16-2006, 01:15 PM
Try not, Do or Do not
Henry Schmidt's Avatar
General rule is that copper sealing rings are used when sealing steel to steel. Aluminum sealing rings are used when seal steel to aluminum.
However one can be used to substitute the other.
Most fuel head rebuilders throw the little filters away.
To my knowledge there is no place to buy these filters.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-17-2006, 04:41 PM
