WOW, Check out that cool distributor !!
Where ever did you get it?:) I know, a cheap self promotion. http://forums.pelicanparts.com/uploa...1156426744.jpg |
Funny guy! Yup, that's a Supertec distributor with one of the Marelli caps and Burn-Bros rotors. If anyone is considering something like this I would highly recommend a conversation with Henry - great advice, the price was quite reasonable and the installation went off without a hitch.
Thanks Henry! AM |
OK, Andrew, give us the dirt now that you have had time shaking the motor down.
Well, the engine seems to be running very well so far. It seems a bit rich on the idle circut, so I'm going to have that checked this week along with a dyno pass or two to make sure A/F is correct all the way through the range. I've been running it through some hills around my house and I think the rings are seating ok, but I'm not really sure how to make sure (leakdown test?)
Overall - I'd rate the experience A+ Too bad it's stating to frost over in the morning and snow will be around the corner If I get a print out of the dyno work, I'll post it. AM |
| All times are GMT -8. The time now is 12:08 PM. |
