LinkBack | Thread Tools | Rate Thread |
ARP Head Stud Height Does Not Matter, Look at Pics of my 3.2L Head Stud Comparison
Ok, let's try this again...my pictures did not upload.
Well I'm going to be doing my ARP install this morning and I read everyone's input on the subject, I have to agree with Henry and a few others that it appears that head stud install height does not matter with aftermarket performance studs since they do not use the barrel nuts. To prove it out I installed an ARP and OEM stud next to each other; The ARP was installed all the way in until it bottomed out and then backed out 1/4 turn. The OEM was installed at a deck height of 135 mm (5.315"). I took a few pictures of their resting positions and you can see that the ARP and OEM threads nearly line up. Before I add the loctite any more advice out there? I already thoroughly cleaned out the threads? Oh, one more question....how much loctite should I put on and should it be applied to the case and not the threads on the stud? Best Regards, Alex
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
It takes a extra few seconds each to set the height properly so why not do it? I assembled a cylinder and a head and then put the washer and nut on to make sure I did not go past the threads....
I can't remember the height I used, but I set them all to the tested height. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Actually, the height with the ARP heads studs installed they way I described was nearly dead on. Let me try to upload the pictures again.
Thanks, Alex
Author of "101 Projects"
Try shortening your image filename.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks Wayne!
Let me try uploading again, I think the pics tell a lot. Best Regards, Alex
looking good, That is about how mine looked.
Cheers
