A few Questions on my HS project
Hi, I'm replacing head studs on my 84 carrera,
my motor's on the ground now with the fuel inj removed. First off, what do I need in terms of hardware to mate the Mainley custom adaper ring thats on its way to the engine / engine stand? and do I have to remove the clutch to mate this up? Do I need to buy that Snapon stud tool, or will double nutting / vise grips / Craftsman stud tool suffice? What should I do about a new O2 sensor? and does it require the special socket? I forgot to check to while it was still in the car and acessable...can I squeeze a craftsman allen socket into the exhauast stud hole in the Heat Exch. or do need that long allen head for sure? What thread chaser do I need for the stud holes? Regards, John |
| All times are GMT -8. The time now is 02:19 AM. |
