New cylinders?
Can you put 3.0 clyinders on a 2.7 7R case...
If so can you add the 3.0 heads?
What are the problems associated with it.....
I know its cheating but hey you cant blame a guy for trying can you?
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 06-21-2006, 07:54 PM
If I'm not mistaken I believe the head stud spacing is different, so it's not possible.
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 06-21-2006, 08:01 PM
3 restos WIP = psycho
kenikh's Avatar
Anything is possible, but the kind of welding and machine work required to do it would make Jerry Seinfeld's pocket book quiver. Well, not REALLY, but it isn't worth going down this path.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-26-2006, 04:05 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Some of you young guys who were wearing diapers in the '80's need to know what was available in the old days...
Mahle did in fact make a 95mm piston/cylinder conversion kit specifically for the 2.7L engines to make 3.0L in displacement, with piston domes available for both MFI/Carbs as well as CIS. Case spigot bore had to be increased to 100mm to use them..
The Mahle 93mm (for 2.9L) pistons/cylinders were found to be more reliable and less costly due to no case machine work necessary (case bore was still 97mm) except for casesavers. Some engine builders believe that they're still over the edge and one really shouldn't go over 92mm with the 2.7L case.
If you look hard enough and really want to pursue it, you might find a set of 95's specifically for the 2.7L (for a 3.0L) or 2.4L (to make 2.8L) but caveat emptor...
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 06-26-2006, 08:37 PM
shbop's Avatar
Too funny!!
Jon
Old 06-27-2006, 12:21 AM
LOL,......and I'm one of those.
Those 93's don't stay round when hot and you can see that in the leakdown figures. IMHO, 92mm ones should be max on any 2.4 or 2.7 case.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-28-2006, 10:46 AM
Do 92's stay round when hot even at 8,000 rpm?
Old 06-28-2006, 04:28 PM
Its not an RPM issue, its heat issue,....
Lack of mass combined with a lot of heat is what makes all thin-wall cylinders lose concentricity at operating temperature.
The Mahle 92's are OK (I use them), but not as thermally stable as the 90mm ones. Charlie's Nickie's might be better in this regard but one must use an aftermarket piston unless you are fortunate enough to have some Mahle's laying about.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 06-28-2006, 09:44 PM
