Information Overloader
964 Cams/valve adjustment
I'm pretty sure the valve clearance with 964 cams is .004 same as stock; correct? Can someone quickly confirm this. Also, is the rocker/cam clearance between .0025 and .003 also same as stock?
Thanks.
Old 05-25-2006, 06:56 AM
Jeff Alton's Avatar
Valve clearance is the same.........
Cheers
www.turn3autosport.com
Old 05-25-2006, 07:18 AM
Thanks Jeff.
Jim
Old 05-25-2006, 07:19 AM
Jim,
The rocker/cam clearance is .00285" when the rocker/valve clearance is .004".
Simple actually, the rocker ratio is 1.4 to 1. Divide .004" by 1.4 equals .002857143", rounded off to .00285".
Check the rocker/cam clearance with a .003" shim. If the shim slips in between, the gap is too big, over .004" at the rocker/valve.
Then check with a .0025", it should slip in between the rocker/cam.
If it does fine, if it doesn't the gap at the rocker/valve is less than .0035".
So the .003" is the over gauge, the .0025" is the under gauge.
Works fine, don't need some special shim holding tool.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 05-25-2006, 06:53 PM
DRV2FST's Avatar
Would this advise be the same for a 965?
Kirk
Crashed: Silver 1992 Turbo S2
Sold: '86 930 minor mods; '94 3.6 Turbo; '85 Euro 930 (3.2 Intake, Tec3r EFI, TwinPlug, Garrett Turbo, JE 8.1 Pistons, 505 rwhp)
Old 06-28-2006, 01:32 PM
DRV2FST,
Since the 965 turbo is based upon the 964 engine, I would expect the rockers are the same.
From what I understand, the 993 engine, with the hydraulic rockers was the change over.
My best advice,
DOUG
Old 06-28-2006, 07:21 PM
DRV2FST's Avatar
Thanks. I guess I'll get into that this weekend.
Kirk
Old 06-29-2006, 06:52 AM
